Accessing the Windscreen Tab on the Ribbon
The Windscreen tab is not displayed on the ribbon by default, as it contains advanced tools related to creating windscreen antenna elements. To access the Windscreen tab, you must configure the ribbon to show the tab.
On the Home tab, in the Extensions group,
click the Windscreen icon.
When the Windscreen tab is enabled, it is
displayed between the Transform tab and Source/Load tab.
