Apply the split operation at a specified plane to divide the geometry
part.
Select the geometry part that you want to split.
On the Construct tab, in the Modify
group, click the Split icon.
Under Origin, specify the position of the plane to split
the geometry.
Under Plane, select one of the following:
Under Rotate split plane, specify the angle of rotation
around the plane selected in Step 4.
Click Create to split the geometry and to close
the dialog.
