Apply a solution coefficient data definition and use as an impressed current source
at a specified point in space.
On the Source/Load tab, in the
Equivalent sources group, click the Solution Coefficient icon.
In the Magnitude scale factor field, specify the scaling
factor.
In the Phase offset (degrees) field, specify the phase
(in degrees) to be added to the phase of the currents.
In the Solution coefficient data field, specify the
solution coefficient data to be used to define the solution coefficient
source.
In the Position field, specify where the source is to be
placed.
In the Label field, add a unique label for the solution
coefficient data source.
Click the Create button to create the solution
coefficient source and to close the dialog.
