Apply an array of electric and magnetic dipoles in the model (in the form of a
planar, cylindrical or spherical aperture) that is equivalent to measured or calculated
field values.
On the Source/Load tab, in the
Equivalent sources group, click the Near field icon.
In the Magnitude scale factor field, specify the scaling
factor.
Tip: Use the scaling factor when data files have different units
(for example, μV/m).
In the Phase offset (degrees) field, specify the phase
(in degrees) to be added to the phase of the fields.
In the Field data field, specify the field data to be
used to define the near field source.
In the Label field, add a unique label for the near
field source.
Click the Create button to create the near field
source and to close the dialog.
