Adding a Current Source
Apply a current source to a line port in a dielectric region solved with the finite element method (FEM) to realise an impressed current source.
Note: An intrinsic limitation of the impressed current source is that no radius is
considered. The field is singular in the vicinity of the filament affecting the
accuracy of the computed input impedance of the source.
