Cuboid
Create a cuboid.
Tip: Press C,1 to use the shortcut key.
Method 1: Base corner, width, depth, height
Base corner (C) | One corner of the cuboid. |
Width (W) | The cuboid dimension in the U axis direction. | |
Depth (D) | The cuboid dimension in the V axis direction. | |
Height (H) | The cuboid dimension in the N axis direction. |
Method 2: Base centre, width, depth, height
Base centre (C) | The base centre of the cuboid. |
