Cuboid
Create a cuboid.
On the Construct tab, in the Create solid group, click the  Cuboid icon.
Tip: Press C,1 to use the shortcut key.
Method 1: Base corner, width, depth, height
Base corner (C) One corner of the cuboid.
Width (W) The cuboid dimension in the U axis direction.
Depth (D) The cuboid dimension in the V axis direction.
Height (H) The cuboid dimension in the N axis direction.
Method 2: Base centre, width, depth, height
Base centre (C) The base centre of the cuboid.
