An oversized mesh element is a triangle with an edge length larger that the specified
maximum edge length. Oversized mesh elements can result in reduced accuracy in the simulated
results.
Select the model or geometry part either in the model tree
or 3D view.
On the Mesh tab, in the
Find group, click the Oversized elements icon.
Specify the parts to be searched for oversized mesh elements.
To search the full model, under Search, click
Entire model.
To search only the selected part of the model, under
Search, click
Selection.
In the Length field, enter a value that is taken as the
upper limit for triangle length. Any triangle length longer than this length
will be marked as oversized.
Click Find to search for oversized mesh elements and to
close the dialog.
The result of the search is displayed in the message window. A hyperlink to the part containing the oversized mesh
element is also given in the message window.
