Apply a scale operation on the selected geometry part.
Select the part that you want to scale.
On the Transform tab, in the
Transform group, click the
Scale icon.
Figure 1. The Scale dialog.
Under Origin, specify the origin around which the
scaling is applied.
Under Scale factor, specify the scaling factor.
Click OK to scale the selected geometry part and
to close the dialog.
