XML File Format for Importing Media
View the .xml file format that describes the medium properties of a dielectric, metal or impedance sheet.
Overview
Define the medium using the following workflow:
  1. Define the frequency independent (static) properties for the medium using keywords.
  2. Define the frequency dependent properties for the medium using keywords.
When the file is read, the internal XML parser fills in the missing values in the frequency dependent data points using the static data points.
Keywords for the .xml file
Use the following keywords to define the medium:
Dielectric
freq, permittivity, diel_loss_tangent, mag_loss_tangent, conductivity, permeability.
Metal
freq, conductivity, permeability, mag_loss_tangent.
Impedance sheet
freq, surf_imp_re, sur_imp_im
Example of a .xml file
The following is an example of a .xml file that describes a medium with frequency independent (static) values as well as measured frequency independent values.
Note: For demonstrative purposes, the keywords val_A, val_B and val_C are used as the same format is applicable for defining a dielectric, metallic or impedance sheet.
<materialDB creator="Altair Feko" date="2017-06-29" version="1.0">
<material name="mediumA" val_B="7.0" val_C="9.0" >
<dataPoint freq="2.0" val_A="2.0" val_B="6.0" />
<dataPoint freq="3.0" val_A="3.0" />
<dataPoint freq="4.0" val_A="1.0" />
<dataPoint freq="5.0" val_B="5.0" />
<dataPoint freq="6.0" val_A="1.0" />
<dataPoint freq="8.0" val_B="6.0" />
<dataPoint freq="9.0" val_A="4.0" />
</material>
</materialDB
In line 3: Define the frequency independent (static) properties for mediumA.
In line 4 to 10: Define the frequency dependent properties for mediumA.
The internal XML parser then fills in the missing values. The above example is parsed internally as if you specified the following file:
<material name="mediumA" >
<dataPoint freq="2.0" val_A="2.0" val_B="6.0" val_C="9.0" />
<dataPoint freq="3.0" val_A="3.0" val_B="7.0" val_C="9.0" />
<dataPoint freq="4.0" val_A="1.0" val_B="7.0" val_C="9.0" />
<dataPoint freq="5.0" val_B="5.0" val_C="9.0" />
<dataPoint freq="6.0" val_A="1.0" val_B="7.0" val_C="9.0" />
<dataPoint freq="8.0" val_B="6.0" val_C="9.0" />
<dataPoint freq="9.0" val_A="4.0" val_B="7.0" val_C="9.0" />
</material>
</materialDB>
Figure 1. An illustration showing the result of the parsed XML file.
