Create an anisotropic medium by defining the diagonal-permittivity tensor and
diagonal-permeability tensor along the UU axis, UV axis, UN axis, VU axis, VV axis, VN axis, NU axis, NV axis and NN axis.
Tip: Create up to nine dielectrics constituting the medium properties
On the Construct tab, in the Define group, click the Media icon. From the drop-down list, select the Anisotropic medium (3D) icon.
In the Tensor type field, from the drop-down list select Full tensor.
For each entry, select one of the following options:
To use the medium properties of free space, from the drop-down list select Free
space.
To indicate that no linear dependencies exist between the two axes, from
the drop-down list select 0.
To use the medium properties of a predefined dielectric, from the drop-down list, select the dielectric.
To use the medium properties of a dielectric, which is not yet defined
in the model, click the icon to define the dielectric or add a dielectric from the media
library.
[Optional] In the Mass density
(kg/m^3) field, enter a value for ρ.
Click Create to create the anisotropic medium and
close the dialog.
