Media Library
The media library contains a list of predefined and user-defined media. You can either add a predefined medium from the library to your model or add your medium to the library.
On the Construct tab, in the Define group, click the Media icon. From the drop-down list, select the Media library icon.
Note: The medium type is indicated in the Source column.
- Predefined media (provided as part of the Feko installation) are indicated by the text Altair Feko.
- User defined media are indicated by the text User.
