Apply the loft operation between curves, between surfaces or between an edge and face
to create a smooth surface.
Select the two geometry entities that you want to loft.
On the Construct tab, in the Extend
group, click the Loft icon.
To achieve a valid loft, it may be necessary to reverse the orientation of
one of the profiles in the loft, so that the bounding edge matching is done in the
opposite direction along the profile.
[Optional] Select the Reverse orientation check box to
reverse the orientation of one of the profiles in the loft.
When lofting closed edges or faces, you can introduce twists or remove
twists to change the relative alignment of the two profiles in the
loft.
In the Alignment index field, increase the number to
change the alignment index.
In the Label field, specify a unique label for the loft
operation.
Click the Create button to apply the loft
operation and to close the dialog.
