Create a smooth surface by connecting two curves, two surfaces or an edge and a
surface; or connect two surfaces to create a solid shape.
Loft any geometry parts that contain edges / faces. Solid or closed regions cannot be
lofted.
For surface bodies, the body must have a single boundary which does not close on itself
and no edge may be attached to more than two faces.
For curve bodies (bodies without faces), the body must be continuous. Open profiles
(arcs) and closed profiles (circles) may be lofted, but cannot be used together in a
single loft. A valid surface loft can be created, for example, between two lines,
between two circles (closed elliptical arcs), between a line and an open polyline, or
between a circle and a closed polyline, but a line cannot be lofted to a circle or to a
closed polyline.
Different surface primitives, such as ellipses and rectangles, can be specified as the
loft cross-section profiles to create a solid body.
If the two loft profiles have an equal number of edges or vertices, the loft operation
connects each pair of edges. For an unequal number of wires / edges, some vertices on
one profile are matched to a single vertex on the other profile. Points can be imprinted
on one or both of the profiles to improve matching, or to influence the shape of the
loft.
When lofting closed edges or faces, use the Alignment index to
change the relative alignment of the two profiles in the loft, thereby introducing or
removing twists.
Loft operations can be performed on edges / wires and faces within parts if the selected
entities are of the same type. Entities within parts are copied out during the loft
operation.
Note: Copied entities are snapshots of the model when the copy was made.
The resulting loft is not linked to the parent object in any way and will not update
with changes made to the original geometry.
