Global and Configuration Specific Entities
Entities such as frequency, sources, loads and power can be set globally or specified per configuration.
- Global
- Global refers to entities that are relevant to all configurations. Tip: Sources defined globally are applicable to standard configurations since sources are not applicable to S-parameter configurations. Sources are not required for characteristic mode configurations, but can be added.
- Configuration-specific
- Configuration specific entities are only applicable to a specified configuration. For example, frequency per configuration and sources per configuration. Configurations inherit all global items.
Note: By default, frequency, sources, loads and power are set globally.
