Converting Configuration Specific Entities to Global
Convert a configuration specific entity to a global configuration.
As an example, loads from a configuration are converted to global loads, but the steps are similar for converting frequency, sources and power.
  1. In the model tree, click Loads.
  2. From the right-click context menu, select Specify loads globally.
  3. On the Choose configuration dialog, from the drop-down list, select the configuration whose loads are to be converted to global loads (and as a result inherited by all configurations).
  4. Click OK to create the loads and to close the dialog.
