Cable Schematic Display Options
View the display options for the cable schematic view.
Icon Name Description
Rotate Rotate the selected item.
Cross sections Show / Hide the cable-cross section display.
Connector spacing Set the spacing factor between connectors on the cable schematic view.
Projection Projection on the XY plane.
Projection Projection on the XZ plane.
Projection Projection on the YZ plane.
