Rearranging Cables in a Cable Harness
All tubes in a harness can be randomly located and packed using the “Rearrange cross sections” tool.
  1. In the model tree, select the cable harness for which you want to rearrange the cable instances.
  2. On the Cables tab, in the Tools group, click the  Rearrange cross section icon.
    In the model tree, double-click the cable harness to view the rearranged cross-section.
    Note: To rearrange the cables inside the cable bundle, from the Modify bundle dialog, click Rearrange.
    Figure 1. The cross-section of the cable harness before the rearrange.
    Figure 2. The cross-section of the cable harness after the rearrange.
