High Frequency Approximation Skin Effect
This option adds a high frequency approximation skin effect.
Figure 1. The SK - Add a skin effect (finite conductivity) dialog.
Note: The material parameters for the skin effect are defined with the DI card. The SK card then uses the label defined at the DI card.
Parameters:
Thickness of elements
The thickness d of the surface elements in metres (if an SF card is present, this is always scaled).
Material label
Label of the material which will be used (as specified in the DI card).
The required parameters are: μ r , tan δ u and σ (defined with the DI card). If applied to surfaces then also the thickness d is required.
The following restrictions apply:
  • A good conductivity is required, satisfying the condition σω ε 0 .
  • For wires the skin depth must satisfy the condition δ skin <ϱ where ϱ is the wire radius. The surface impedance is given by Z s = 1 2πϱ jωμ σ .
  • For metallic surfaces the skin depth must satisfy the condition δ skin < d 2 . The surface impedance is given by Z s = 1 2 jωμ σ .
