Creating the Port
Define a wire port on the feed pin. A voltage source will be added to this port.
  1. Select Union1.
    1. In the model tree, select Union1.
    2. In the details tree, select the wire of Union1.
  2. Define a wire port using one of the following workflows:
    • On the Source/Load tab, in the Ports group, click the  Wire port icon.
    • In the details tree, a right-click context menu is available on the wire. From the drop-down list, select Create port > Wire port.
  3. Under Location on wire, select Middle.
  4. Click Create to create the port and to close the dialog.
