Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
  1. Use the model considered in SEP Model and rename the file.
  2. Set the solution method for all regions to FEM.
    Tip: Open the Region properties dialog and click the Solution tab. From the Solution method list, select Finite Element Method (FEM).
  3. Set the data storage precision to Double precision for faster convergence.
    Note: Open the Solver settings dialog and click the General tab. Under Data storage precision, select Double precision.
