Meshing the Model
Create the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
  1. Set the Mesh size equal to Custom
  2. Set the Triangle edge length equal to a/4.
  3. Set the Wire segment length equal to h/10.
  4. Mesh the model.
    Tip: A small distance separates the dipole and rectangular plate. Use a finer than Standard mesh setting for the LE-PO.
