Changing the Line Styling
Change the line style, line colour and line weight of a selected trace. Change the line style, line colour and line weight of the title, footer or axes from a selected surface graph.
Select the graph where you want to change the line style, line colour and line weight and click the trace. Select the surface graph where you want to change the line style, line colour and line weight and click the title, footer or axes.
  1. Change the line style of the selected title, footer or axes. Change the line style of the selected trace.
    1. On the Format tab, in the Line group, click the Line style icon.
    2. Select one of the following:
      • To remove the line style, click None.
      • To modify the line style, click the line style you want to use.
  2. Change the line colour of the selected trace. Change the line colour of the selected title, footer or axes.
    1. On the Format tab, in the Line group, click the  Line colour icon.
      • To modify a colour, click the marker colour you want to use.
      • To add a colour that is not included as one of the basic colours, click More colours.
  3. Change the line weight for the selected trace. Change the line weight for the selected title, footer or axes.
    1. On the Format tab, in the Line group, click the  Line weight icon.
    2. Select the line weight you want to use.
