List Jobs
To show the status of jobs recently submitted, use wx list.
The default is to show up to 20 jobs submitted by the user running wx list. With some options, described below, you may also view jobs belonging to other users.
Note: This command can impose a significant load on the system. Please review the help info below for suggestions how to obtain job info efficiently.
The Accelerator Plus Administrator may have configured methods to mitigate this load, including caching and use of a subserver process to handle wx list commands.
wx list
wx: Usage Message
  WX LIST:
          List jobs currently in the system.
          The list is ordered by increasing job id,
          normally the same as the submission order.
          The behavior can be controlled by $VOVDIR/local/vnclist.config.tcl
          and by the variables
          NC_LIST_FORMAT
          NC_LIST_CACHE_DIR
          NC_LIST_CACHE_TIMEOUT
  NOTE ON CACHES and MORE EFFICIENT METHODS:
          This command may use local, client-side caches.
          Caches are activated by setting NCLIST(cache,enable) to 1
          in the file $VOVDIR/local/vnclist.config.tcl
          These caches can significantly reduce
          the load on the scheduler in the case of repeated calls.
          The default timeout for these caches is 30s.
          There are better ways to get information about jobs, especially in
          scripts.  Please consider the following efficient methods:
          % wx getfield $JOBID ...
                -- To get specific info about a job
          % wx cmd vovset count SETNAME ...
                -- To count jobs in sets by status
          % wx wait ...
                -- To block waiting for jobs to complete
  USAGE:
          % wx list [OPTIONS]
  OPTIONS:
          -O <format>       -- Specify a different Output format.
                               Refer to the manual for a description
                               of formats. For experts.
                               This can also be specified via the NC_LIST_FORMAT
                               environment variable.
          -O+ <format>      -- Add one or more fields to the default output
                               format.
          -H                -- When used with -O, show header line.
          -l                -- Long format: show group, user, host,
                               and full command.
          -L                -- Very long format: show start and end dates,
                               duration.
          -c                -- Count jobs: this option affects the output
                               format.
                               It adds a column with the the position of each
                               job in the list of jobs to be shown.
          -S <rule>
          -select <rule>
          -selrule <rule>   -- 3 ways to specify the selection rule. For
                               experts. The clause 'isjob' is added to the
                               selection rule.
          -S+ <rule>        -- Alternate (OR) selrule; jobs that match any
                               selrule will be shown. The clause 'isjob' is
                               added to the selection rule.
          -subjobs          -- Show also sub-jobs too
                               (e.g. jobresumer, partialtool)
          -systemjobs       -- Show also system-jobs
          -alljobs          -- Show all types of jobs,
                               including sub-jobs and system-jobs.
          -a                -- Show jobs for all users.
          -r                -- Show only running jobs.
          -f                -- Show only failed jobs.
          -s                -- Show only suspended jobs.
          -q                -- Show only queued jobs.
          -u <user>         -- Show jobs belonging to given user. Ignored if
                               used with -selrule or -set option.
          -first <index>    -- Show jobs starting at index. By default,
                               first index is 1.
          -last  <index>    -- Show jobs ending at index. By default, last
                               index is -1, which is the last job.
          <num>             -- Show first <num> jobs if <num> is positive.
                               Show last <num> jobs if <num> is negative number
          -J <jobName>      -- Show only jobs with given job name.
                               WARNING: this option can place a high load on
                               the WorkloadXelerator server in large workload
                               environments due to the need to compare strings
                               for each job, it is recommended to avoid calling
                               this unless truly required.
          -set <setName>    -- Show only jobs in the given set.
                               This option can be repeated to show the content
                               of multiple sets.  If a job belongs to multiple
                               sets, it may be reported more than once.
          -dir <directory>  -- Show only jobs in the given directory.
          -ss               -- Use subserver, if available.
          -cache            -- Use result cache. It is recommended to utilize
                               the result cache to reduce the load on the
                               in cases where list queries are scripted.
                               By default, the cache expires after 30s.
          -noss             -- Do not use subserver, even if available.
                               (Default)
          -v                -- Increase verbosity.
          -h                -- Print brief usage.
  EXAMPLES:
          % wx list
          % wx list -c
          % wx list -a -l
          % wx list -O "@USER@ @GROUP@ @DURATION@"
                            -selrule "duration>60"
          % wx list -H -O "@USER@ @GROUP@ @DURATION@"
                            -selrule "statusnc==Failed"
          % wx list -dir .
          % wx list -a -r -s
                            (Show all running and suspended jobs)
          % wx list -selrule "duration>600 statusnc==Running"
          % wx list -first 10 -last 20
          % wx list 5
          % wx list -10
