License Violation Effects and Actions
Monitor requires a license in order to store and report on historical license utilization information. If at any point a license is not available while the server is running, the server enters a licensing "grace period" of five days and the system will continue to operate as normal.
- The Altair Accelerator license is expired.
- If using RLM, the license server is down at the time of the entry in the log. If using a license key file, the key file is missing. In either of these two cases, all data will be obfuscated until license availability is restored.
- There are more observed users across the various monitors than what the Altair Accelerator license contains. For example, for a license of 50 users, and Monitor detects 56 unique users at a given point in time, the server assigns an index to each unique user and all checkouts for users 51 to 56 will be saved as an obfuscated entry.
Deobfuscation
- Web-based Interface
- To check for the existence of obfuscated data and deobfuscate it, visit
the Database Information area of the
System page, located in the
Admin tab. If obfuscated data has been
generated by the system, the data files that contain the obfuscated data
will show up at the bottom of the page, along with a button to use to
perform the deobfuscation:
Figure 1. Database Information Page - Command Line Interface
- In the CLI, the lmmgr deobfuscate command can be
used. To use the command, first setup the CLI:
% vovproject enable licmon
After setting up the CLI, the command can be executed:% lmmgr deobfuscate
If more precise control over the deobfuscation process is required, use the ftlm_deobfuscate utility instead:ftlm_deobfuscate: Usage Message DESCRIPTION: Utility to deobfuscate and load checkouts that have been obfuscated by LicenseMonitor during situations where the product license was either unavailable, exceeded, or expired. If no file is specified, the utility automatically detects and deobfuscates all log files that contain obfuscated data. USAGE: % ftlm_deobfuscate [OPTIONS] OPTIONS: -h -- Show this help. -v -- Increase verbosity. -do -- Perform deobfuscation and load data into DB. -k -- Specify license key file path. Default is to search in the following order: licmon.swd/license.lm.key licmon.swd/license.key VOVDIR/local/license.lm.key -show -- Show files that are known to have obfuscated data. EXAMPLES: % ftlm_deobfuscate -do % ftlm_deobfuscate -show % ftlm_deobfuscate -do 2010.04.01 % ftlm_deobfuscate -do 2010.04.*
