Request a License File
We recommend that you request a license file, after setting up the system.
To request a license file, perform the following steps.
  1. From the web interface, go to the Admin tab, and select the Licensing option.
    Figure 1. Licensing Page
  2. Follow the instruction at the bottom to request a license or contact your sales rep. The license will be mailed to you as a text file.
  3. Open the file. Save the license file under the licmon.swd directory, (c:/rtda/swd) which can be found in the executable window under the Working Server Directory.
  4. Rename the license file to license.key. If a prompt comes up asking you to confirm the change in file type to key, confirm the change.
  5. Go back to the web interface and go to the Admin tab and select the Licensing option.
  6. Click Re-acquire all Licenses.
    Figure 2. License Status
