Installation
The installation section is divided into five sections, an introduction with system requirements, and four different types of installations.
You will either install with Single File Distributable (use this if you are ONLY installing Monitor and no other products), or install with Multiple File Bundles, (use this if you are installing several Altair Accelerator products at once). Further, you will install the product according to your operating system, Windows or Linux.
