Monitor monitors tools with licenses using live sampling and debug logs for denials, and it monitors tools with no licenses
using wrapper scrips and a monitoring agent.
This section explains how to use Monitor to answer common questions. In most cases, there isn’t one answer to a question. Some investigation is required.
By default, no links will show until you have configured them. You can add links to your Home tab to more efficiently
manage your system, and we recommend you do that once you have configured the system.
The Current tab shows a summary of features with active checkouts the moment the page is loaded. By hiding the features
that have no usage, this page shows the location of the license activity.
The Views functionality of Altair Monitor allows an authenticated user to create a high-level table-based status report that shows only the items desired
by the user.
Altair Monitor is a software license tracking tool that reports current and historical license utilization. The license managers
that Monitor supports includes FlexNet Publisher, Reprise, LUM, and unlicensed tools. The primary user interface for accessing Monitor is a web interface.
your Home tab to more efficiently manage your system, and we recommend you do that once you
You must have Admin permissions to perform this take.
To add a link, go to the Admin page and select the
Links option.
Figure 1. Add a Link
Type in the link name and add a URL.
Click Create Link.
When you return to the Home tab, Links will show this as
option.
To delete the link, return to the Admin tab and select the
Links option.
