Agents
This option enables you to add, manage and run agents on remote machines.
- If the Altair Accelerator installation and remote connectivity (ssh, rsh, or vovtsd) to the remote machine are both available, you can use the form on this page to add agents.
- If the Altair Accelerator installation or remote connectivity is not available, you need to set up agents locally on the remote machine
Figure 1. Agents Options
- To learn how to set up an agent via the web interface, go to Add and Configure an Agent using the Web GUI.
- To set an agent up with the CLI, go to Add an Agent – File-Based Configuration.
