LUM
Usage
add_LUM [OPTIONS]
Options
-cmd <PATH> Choose a specific sampling command. The default is LUMblt
-col Specify that the LUM server being monitored is serving concurrent offline licenses.
-host <HOST>
-port <PORT> Set artificial server port to show in reports. Default: 0.
-tag <TAG> Specify the TAG to identify the license server. The TAG may contain only alphanumeric characters and underscores (_). The use of upper case characters is recommended for style purposes.
-trackdenials If provided, denial information from denials in addition to usage.
-tracktestlics Track common LUM test licenses, such as iFOR Test Product and HAL Test Product.
-tz, -timezone Set to timezone which was used to generate the debug log. Ex: PST8PDT. If debug log was generated in the same timezone as the Monitor server, leave blank.
-minStatPeriod <TIMESPEC> Minimum sampling period for usage.
-maxStatPeriod <TIMESPEC> Maximum sampling period for usage.
-maxInfoPeriod <TIMESPEC> Maximum sampling period for expiration dates.
-minDenialPeriod <TIMESPEC> Minimum sampling period for denials.
-maxDenialPeriod <TIMESPEC> Maximum sampling period for denials.
-infoAutokill <TIMESPEC> Kill info parsing job after specified time.
-statAutokill <TIMESPEC> Kill stat parsing job after specified time.
-denialAutokill <TIMESPEC> Kill denial parsing job after specified time.
