## Altair alus.conf file
## Server Logging Level (Altair Specific Logging)
## Possible values are:
## 0 No Altair Specific Logging
## 1 Errors (Default)
## 2 Debug
## 3 Info
ALUS_DEBUG_LOG_LEVEL=1
## Location and settings of files for license server and reporting tools
ALUS_PENDING_DIRECTORY=/usr/local/altair/licensing13.0/data/pending
ALUS_PROCESSING_DIRECTORY=/usr/local/altair/licensing13.0/data/processing
ALUS_SCRATCH_DIRECTORY=/usr/local/altair/licensing13.0/data/scratch
ALUS_DETAILED_DIRECTORY=/usr/local/altair/licensing13.0/data/detailed
ALUS_LOGGER_DIRECTORY=/usr/local/altair/licensing13.0/data/logs
ALUS_MANUAL_DIRECTORY=/usr/local/altair/licensing13.0/data/manual
ALUS_SENT_DIRECTORY=/usr/local/altair/licensing13.0/data/sent
ALUS_INVALID_DIRECTORY=/usr/local/altair/licensing13.0/data/invalid
ALUS_UNDELIVERABLE_DIRECTORY=/usr/local/altair/licensing13.0/data/undeliverable
ALUS_UNDELIVERABLE_DB_FILE_PATH=/usr/local/altair/licensing13.0/data/undeliverable.properties
## Location of Decay Directory
ALUS_DECAY_DIRECTORY=/usr/local/altair/licensing13.0/decay
## Location of 3rd party license files for Catia Readers
#TTF_LICENSE_FILE_PATH=/usr/local/altair/licensing13.0/ttfLicense.txt
## Setting for Altair Logging level of transactional data
## 0 = No logging
## 1 = Anonymized only
## 2 = Anonymized and Detailed
ALUS_LOG_LEVEL=2
## Location of script to run reporting tool
ALUS_URT_LOCATION=/usr/local/altair/licensing13.0/bin/urt.sh
## Number of attempts to transmit data each week
ALUS_MAX_ATTEMPTS=2
## Address of the Altair Usage Collection Server for HTTP
## **Only one pair of the addresses below should be uncommented.**
ALUS_ALAS_URL=http://urtserv01.altair.com/NewURT
ALUS_WSDL_URL=http://urtserv01.altair.com/NewURT/services/AppServer
## Address of the Altair Usage Collection Server for HTTPS
#ALUS_ALAS_URL=https://urtserv01.altair.com/NewURT
#ALUS_WSDL_URL=https://urtserv01.altair.com/NewURT/services/AppServer
## Configuration of proxy should be either HTTPS(SSL) or HTTP.
## Please uncomment the settings below to match the address chosen above
## choose either ALUS_HTTP_ or ALUS_HTTPS_ to match http or https from above
## settings of ALUS_ALAS_URL and ALUS_WSDL_URL
## HTTP Proxy setup (choose this one or the HTTPS below)
## user and password should not be set if they are not required
## by your proxy server.
#ALUS_HTTP_PROXYHOST=
#ALUS_HTTP_PROXYPORT=
#ALUS_HTTP_PROXY_USER=username
#ALUS_HTTP_PROXY_PASSWORD=password
## HTTPS(SSL) Proxy setup (choose this one or the HTTP one above)
## user and password should not be set if they are not required by your proxy server
#ALUS_HTTPS_PROXYHOST=
#ALUS_HTTPS_PROXYPORT=
#ALUS_HTTPS_PROXY_USER=username
#ALUS_HTTPS_PROXY_PASSWORD=password
## Optional email address for usage report confirmation
## uncomment and set to a single email address to recieve confirmation
## from the Altair server after report delivery
## PLEASE NOTE THAT THIS ADDRESS IS SENT TO THE ALTAIR SERVER EACH
##TIME THE URT SENDS DATA. IT IS NOT RETAINED FOR FUTURE USAGE.
#REPORT_CONFIRMATION_EMAIL=user@domain.com
