Calibre Turbo
vovcalibremt
vovcalibremt is a script to support the parallel distributed version of calibre with MTflex. This script is designed to be invoked in N identical instances on all machines used for the run, with the instance 1 becoming the calibre master while all other instances become the calibre slaves.
LAUNCH MANUAL WAIT 600 COUNT 16 PORT 10102
LOCAL HOST 4
LOCAL HOST DIR /some/directory
In order to get N identical invocations of the same vovcalibremt command, we can use vovparallel clone. The full invocation of the command therefore is:
% nc run -dp 16 -dpres mt_master,mt_slave -dpwait 4m vovparallel clone vovcalibremt [CALIBRE_OPTIONS]
# This is an example job class file 'calmt.tcl'
set classDescription "Calibre MTflex jobs"
set VOV_JOB_DESC(resources) "License:calibre"
set VOV_JOB_DESC(env) "BASE+RTSIM"
set VOV_JOB_DESC(mpi,resources) "mt_master,mt_slave"; # Deprecated
set VOV_JOB_DESC(mpi,wait) 240 ; # Deprecated
set VOV_JOB_DESC(dp,resources) "mt_master,mt_slave";
set VOV_JOB_DESC(dp,wait) 240
set VOV_JOB_DESC(wrapper) "vw vovparallel clone"
set VOV_JOB_DESC(priority,sched) 9
proc initJobClass {} {
# define resource requiremets for the master (big machine AND a license)
vtk_resourcemap_set mt_master -map "linux RAM/1000 CPUS/1 License:calibre#1" -max unlimited
# define resource requiremets for the slave.
vtk_resourcemap_set mt_slave -map "unix RAM/100 CPUS/1" -max unlimited
The resulting submission line would look like this:
% nc run -C calmt -dp 16 vovcalibremt [CALIBRE_OPTIONS]
