Wrapping Unlicensed Tools
The wrapping technique for monitoring unlicensed tools uses Monitor's built-in license management capability. This basic capability is activated by first creating a served license, then instructing the tool to either count its run as a checkout, or to request a license before being checked out, via a script or binary wrapper. Monitoring occurs automatically.
Creating a License
The vovlmd daemon configuration file, found at licmon.swd/vovlmd/config.tcl, allows for the creation of served licenses. The following is an excerpt from the vovlmd configuration template which details how to create a served license.
### SERVED LICENSES ###
# The following line is required to register licenses to be served.
# Uncomment it to activate served licenses.
# vtkle_features_init
# Create a license
# vtkle_feature_set <NAME> <CAPACITY|unlimited> [OPTIONS]
### Options
# -expire TIMESPEC|never -- Set the expiration time for the license. Can be
# specified in seconds-from-now or a VOV TIMESPEC
# (1d, 1w, 1y). Default is to expire in one hour.
# Note: 1m is 1 minute, not 1 month!
# -log -- Generate a log of activity for debugging purposes.
# The log is located at licmon.swd/logs/features.log.
### Examples
# vtkle_feature_set sqlite 3 -expire never -log
# vtkle_feature_set sqlite unlimited -expire 180d
Using a License
% setenv VOV_JOBCOUNTER 5555@lmsrv,licmon
In the example above, lmsrv
is the Monitor
server name, 5555
is the port (which is the default), and
licmon
is the Monitor instance name (also
default).
% vtool LICENSENAME LICENSEQTY TOOL
vtool: Usage Message
DESCRIPTION:
A tool to execute a command using one or more features managed by the
Altair Engineering-LM license manager. The VOV_JOBCOUNTER environment
variable must point to the license manager vovserver instance using the
format of port@host,instance (eg: 5557@lmhost,licmon).
Multiple instances can be specified by separating them with a colon
(eg: 5557@lmhost1,licmon1:6667@lmhost2,licmon2). If multiple instances
are specified, each subsequent instance will be queried if the requested
tokens were not granted by the previous instance in the list.
By default, each instance must be able to grant the requested number of
tokens in whole. However, scavenging mode (-s) can be used to allow
each instance to partially fulfill the request.
USAGE:
% vtool [-v] [-refresh <S>] -f <feature1> <tokens1> \
[-f <feature2> <tokens2> ...] <command ...>
OPTIONS:
-v -- Increase verbosity.
-f <feature> <N> -- Check-out N tokens of specified feature.
If N is negative, queueing will be enabled for the
absolute value of N tokens.
It is an error for N to be zero.
-refresh <S> -- Specify refresh cycle (time-spec) for tokens
(default is 600 seconds), meaning that
the tokens are refreshed every 10 minutes.
Setting a refresh cycle of 0 disables
the refresh.
-s -- Scavenging mode. When VOV_JOBCOUNTER is set to a
colon delimited list of license servers, a check
out from each server will occur until the target
number of tokens has been reached. If queuing is
enabled, only the last server will enter queuing
mode regardless of its license capability.
SIGNALS:
TSTP -- Release licenses and suspend execution.
CONT -- Resume execution.
HUP -- Caught and ignored
TERM -- Caught and ignored
QUIT -- Caught and ignored
SEE ALSO:
vlmstat vovcounters
EXAMPLES:
% vtool -f lic_drc -1 -f lic_hdrc -1 sleep 10
% vtool -s -f lic_drc 3 sleep 10
% vtool -f lic_drc 3 -refresh 2m sleep 10000
Script Wrapping Example
spice
which performs circuit
simulation and typically runs in a few seconds. The tool uses the feature
expensive_spice
. Because the tool is so fast, the sampling
methodology will capture only a small fraction of the check-outs of
expensive_spice
. The tool's invocation command is: %
spice netlist.spi
.- Set the environment variable VOV_JOBCOUNTER to point at the Monitor server:
% setenv VOV_JOBCOUNTER 5555@HOSTNAME,licmon
- Create a new license called
mirror_spice
. In the vovlmd/config.tcl file add:% vtkle_features_init % vtk_feature_set mirror_spice 10 -expire never -log
- Test the license availability:
% vovcounters vovcounters Wed 17:14:15: message: JobCounter: 5555@bear,licmon vovcounters Wed 17:14:15: message: Wed Oct 10 05:14:15 PM PDT 2007 Counter spice 0 of 5
Another utility, called vlmstat has been provided that provides a look and feel similar to lmstat.
- Create an instrumented script, also called spice as follows:
#!/bin/csh -f # This is the 'instrumented spice' vtool mirror_spice 1 /full/path/to/spice $1
- Using the PATH search mechanism, make sure that when the users invoke spice they find the instrumented script before they find the real spice.
The overhead introduced by the instrumented script is negligible. The statistics
collected for the counter mirror_spice
will be fairly accurate, but
not necessarily an exact, representation of the utilization of
expensive_license
, in those cases in which the job actually
checks out the license many seconds after it starts or checks it in many seconds
before it exits.
Binary Wrapping
Description:
A utility to compile a binary wrapper for a binary in order to
be able to count all invocations of that binary.
The utility compiles a small C program linked to the
libcounters.a library.
This utility is meant to be an example of how you can
use the libcounters.a library.
You are free to look at the details of the script
($VOVDIR/scripts/vovprotectwithcounter.csh)
and modify it to suit your particular needs.
To change the C compiler, set the variable CC.
The output is a binary in the current directory with the
same name as the wrapped binary.
Usage:
% vovprotectwithcounter.csh [-debug] /full/path/to/binary countername tokens
Example:
% vovprotectwithcounter.csh /bin/cp count_cp 1
% vovprotectwithcounter.csh -debug /bin/cp count_cp 1
% env CC="gcc -m64 -g" vovprotectwithcounter.csh /bin/cp count_cp 1
set B = "`basename $0`:"
set B = `basename /integ/zfbuild/integ/builds/201901release/build/common/scripts/vovprotectwithcounter.csh`:
if ( $#argv < 3 ) then
if ( 0 < 3 ) then
cat << EOF
cat
exit 2
exit 2
