Batch Reporting
Batch reporting is available through the ftlm_batch_report
command.
Batch reporting is useful when the report period is long or there is a desire to have more
than one report shown on the web page.
Batch reports are persistent and static: the data they display is accurate as of the time they are built, and remain available until the report files are deleted from the disk.
You may use batch reporting to configure a complex report with html format which includes the corresponding ftlm_batch_report commands, then incorporate such command (with proper modification) in a cron job (Unix) to automate and schedule the report generation.
