License Server Monitoring
Each license server to be monitored must be identified in the Monitor configuration. This can be accomplished by using the Admin web page or by editing the vovlmd configuration file (licmon.swd/vovlmd/config.tcl). The web page maintains a separate configuration, so when using both methods, be careful to configure only one monitor for each tag to avoid configuration conflicts.
Choose a Tag Name
Monitor tags are used to give symbolic names to license servers, and to distinguish between the same feature from different servers, e.g. WAN vs. LAN licenses. Tag names may contain letters, digits, underscore (_), and dash (-) characters ( regexp [a-zA-Z0-9_-]+ ) and are case-sensitive.
When initially configuring Monitor, it is important to choose tag names carefully so they will not need to be changed later. Changing is possible, (see Tag Administration), but it is better to avoid this process by choosing appropriate tag names during the initial configuration phase.
One naming convention that works well is to construct tag names in the form <site>_<vendor>_<type>, where type is e.g. LAN, WAN, since it permits using Monitors filters to easily find things by site, tool vendor, and license type (for example NY_MENTOR_LAN, SF_MENTOR_WAN).
Browser-based Configuration
Figure 1. Monitor Administration Page
The Monitor configurations managed by the web interface are not stored in the main vovlmd configuration file, but are instead written to the licmon.swd/vovlmd/config_aux.tcl file. This file is loaded after the main configuration file and can override it.
File-based Configuration
In addition to the browser-based setup, you may specify license servers to be monitored by editing the .../licmon.swd/vovlmd/config.tcl file. If the file is not already present, you may copy a complete and self-documented example from $VOVDIR/etc/config/vovlmd/config.tcl.
Supported License Managers
The following table shows licensing systems that are supported in this release, and has links to the reference documentation for the configuration options that are available for each system.
System | Config Statement |
Altium Log File | add_ALTIM_LOG |
BETA CAE BETA LM | add_BETA |
ClearCase | add_CLEARCASE |
Wibu CodeMeter Log File | add_CODEMETER_LOG |
Dassault DSLS | add_DSLS |
Dassault DSLS Log File | add_DSLS_LOG |
Green Hills Legacy (Elan) | add_GHS_LEGACY |
FlexNet Publisher | add_LM_LICENSE_FILE |
FlexNet Publisher | add_DEBUG_LOG |
FlexNet Publisher | add_LIC_OPTIONS |
Fujitsu ICAD (Windows only) | add_ICAD |
GNS | add_GNS |
Green Hills | add_GHS |
IBM LUM | add_LUM |
LSTC | add_LSTC |
Wolfram MathLM | add_MATHLM |
Remote Monitor | add_REMOTE_LM |
Reprise RLM | ad_REPRISE |
Altair License Key File (RTDAKEY) | add_RTDAKEY |
Sentinel HASP | add_HASP |
Sentinel RMS | add_SENTINEL |
Silvaco | add_SILVACO |
OLicense | add_OLICENSE |
QF-Test | add_QFTEST |
T-Systems LICMAN | add_TSYSTEMS |
X-Formation LM-X | add_LMX |
Process Tracking | add_PROCESS_TRACKING |
- Configuration Example
add_LM_LICENSE_FILE 5280@lichost1 -tag CADENCE add_LM_LICENSE_FILE 2233@lichost1,2233@lichost2,2233@lichost3 -tag SYNOPSYS add_LM_LICENSE_FILE /vendor/mentor/current/license/license.dat -tag MENTOR add_LM_LICENSE_FILE 1717@lichost4 -tag MGC -lmstat /tools/flexlm/bin/lmstat
About FlexNet Publisher Reservations
In both configuration methods, there is an option to enable the tracking of FlexNet Publisher reservations. Reserved licenses that are not used are considered checkouts by Monitor if this option is enabled. The checkouts are for a special user, beginning with "r:", that includes the reservation object name, so that these checkouts can be distinguished from real usage in the Monitor reports. Enabling this option allows Monitor to quickly and easily identify waste that is created as a result of obsolete and overly aggressive reservations.
Status Command Specification
Command Versions
By default, Monitor searches the system path for the status command. It is common practice to copy the status commands to the $VOVDIR/bin directory so that there is at least a default command always available. However, due to version incompatibilities, this may not always work. For this reason, it is recommended to point to the version of status command that matches that of the license server being monitored.
If a specific status command is defined in the configuration, the path to this command is honored. This is accomplished in the browser interface by filling in the status command form input with a full path to the desired status command. In the configuration file, each license type has a status command argument that is used to specify the location. For example, the -lmstat argument is used to specify a path to the lmstat command for FlexNet Publisher-based monitors.
- Reprise: As of version 2015.03, the vovrlmstat utility is no longer supported. The native rlmstat command now provides expiration information and is the default command utilized when the add_REPRISE monitor is selected. The add_RLM_LICENSE_FILE monitor is to be phased out, and utilizes rlmstat as well.
- Sentinel:Some versions of Sentinel's lsmon utility on Windows have the behavior of requiring the enter key to be pressed at the end of its output dump. This means that when executed as a background task in Monitor, the task will never end. If the lsmon utility being interfaced with exhibits this behavior, make a copy of the vovlsmon.bat script template found in $VOVDIR/bat and place it somewhere outside of the $VOVDIR directory. Modify it to point to the lsmon.exe being interfaced with, then configure the status command to point to this script instead of lsmon.exe directly.
Working With Remote License Servers
ssh remotesrv /usr/local/bin/lmstat
ssh remotesrv env TZ=PST8PDT /usr/local/bin/lmstat
For this to work, you must have an account at the remote site that can remote-shell without a password, by using rsh or setting up ssh to use authorized keys.
