Start Monitor
After downloading Monitor, double-click on the
executable file.
The following window will display:
Figure 1. - Make changes to the directories as desired.
When done, click Start.
The extraction may take time some time. When Monitor is started, you will see “Altair Monitor running as process …” at the bottom of the window.
- With Monitor running, open a web browser and go to http://localhost:5555 and login. Use the same login you use on your home computer.
- Continue with the setup process.
