Server and File Control
This option enables you to edit licensing files, work with licensing files and control license servers. Only the Monitor owner-user has permission to add additional managers on this page.
Figure 1. License Files and Commands
Select a tag by clicking on the License server tag. This brings up the information for the license server instance that the tag represents.
Figure 2. License Files and Commands
This configuration can be edited and saved from within this page. The lower half of the page enables you to View, Edit, Import and Deploy Configuration.
Figure 3. License Files and Commands
