Configure Security Parameters for Specific Users
When you first install Monitor, you should set up permissions for specific users. Only administrators can perform this action.
  1. Go to http://localhost:5555/admin.
    Figure 1. Monitor Admin Page
  2. Scroll down to the Project Configuration Files section, click on Security file link.
    A new page will display, which explains how to set permissions. The page itself defines who has access to the vovserver for Monitor.
  3. Set the security level for the user as Read only, User, Leader or Admin. See the table below for specifics on what each security level indicates.
    User Security Level Description
    Read Only Minimum privileges; a user can only browse the information but cannot change anything
    User
    A user can only execute established flows and view non-critical information. A user can:
    Create, modify or forget his own jobs
    Create, modify or forget his own files
    Create, modify or forget his own set
    Modify or forget dependencies
    Create/modify/start/stop/forget own slave
    Remember jobs owned by other users
    Leader
    A leader can create and execute arbitrary flows and view all non-security related information. A leader can:
    Start or stop his own slaves
    Forget all jobs, including jobs owned by another user
    Save trace database to disk
    Note: This level is rarely used.
    Admin
    An admin has access to most security information. An admin can:
    Forget jobs owned by other users
    Stop jobs owned by other users (no user can modify another user's jobs)
    Stop the server
    Stop/modify/forget the slaves
    Refresh slave cache
    Destroy a user
    Destroy a host
    Create or destroy alerts
    Create, modify or destroy resource map
    Reserve resource
    Create, modify or destroy preemption rule
    Create, modify or destroy multiqueue objects (Monitor sites, NC queues, resources)
    Create, modify or destroy Monitor objects (licdaemons, features)
    The security rule is: vtk_security <userName> <securityLevel> <hostList> where
    • <username> is the case-sensitive login name of a user
    • <securityLevel> is READONLY, USER, LEADER, ADMIN (case insensitive).
    • <hostList> is a list of one or more host names, which is either an actual host name, + to mean any host.
  4. Configure the security parameters in accordance with these rules.
  5. When done, click the Save button.
