Add a License Monitor
To add a license monitor, go to the Admin tab, and select
Monitors from the menu bar.
Figure 1. Adding a New License Monitor -
Enter details for at least sections 1-4.
- Select monitor type.
- Specify a unique tag name.
- Enter license file locations.
- Enter full path to status command.
- On the bottom, click Add New Monitor.
Go to Home tab.
The current checkouts should be populating shortly, within 30 seconds.
- For Windows users, we recommend setting up Monitor as a service, if you haven’t done so already. See Set Up Monitor as a Service – Windows Only.
