Install Monitor
  1. Open a terminal, and go to the directory where Monitor downloaded.
  2. Run the following commands:
    tar -xvf common.tar
    tar -xvf linux64.tar
    The system will display the files and directories that were created.
  3. Double-click on install.csh.
    Figure 1. Installing Monitor
  4. If this is an upgrade, in the Existing Installation Directory Field, enter the path to the existing installation; if this is a new installation, leave this field blank.
  5. In the New Installation Directory field, enter your chosen path. If you are updating a file, we recommend you enter the date of the update in that file heading.
  6. If you have a Monitor license, put the port@host in the appropriate section
  7. Click Start Installation.
  8. Click Exit to close the GUI.
