Move a Database
To move a Monitor database, perform the following steps:
Go to the Admin tab and select System > Configuration Information option.
Figure 1. System Configuration - Uncheck the Load checkout data box and click Update.
From the command line, run:
% vovproject enable licmon vovdaemonmgr stop vovdbd
- Go to the directory where the licmon.swd is located and find where the database is stored under licmon.swd > db >config.tcl.
- Go to that directory and copy the entire postgresdb directory into the new location.
- Edit the config file under licmon.swd>db.
- Change the path of sqlconfig(datadir) to the new path.
Back in the xterm enter:
% vovdaemonmgr start vovdbd
- Return to the Monitor web interface and re-check the Load checkout data box and click Update.
- It may take a few minutes for the system to update.
