Load a Database
This section details the multiple methods by which Monitor loads data into the database, and the configuration options available to control the data that is loaded.
You may need to manually load checkout or denial data into the database. This will be required if importing historical checkout data that is obtained from parsing a debug log, or if reloading data for checkouts and/or denials. It can also be helpful in debugging database loading problems.
