Agent Status
Figure 1. Agent Status Page
When you click Manage Agents, it will bring up the Agent Management page for agents that can be remotely controlled via ssh, rsh, or vovtsd.
The Control Center's license management agents are configured in the same manner as monitoring agents with one exception. Each agent can be assigned to a specific tag, so that it will only interact with the license servers to which those tags are related. This allows for securing tags to their respective administrator personnel.
If such security is not required, the agent can be configured to interact with all tags found on the same machine on which the agent is running.
