</path/to/log> |
The first argument must be a path to a FlexNet Publisher debug log. For a rotating log the name specified must be in the form of
<fileName>.@DATE@.log. See Debug Log Monitoring for
more details. If the server being monitored is of a triad configuration or
if multiple daemons are being served from the server and they each have
their own debug log (meaning that their debug logs were enabled via the
FlexNet Publisher options file), each log will need its
own line along with appropriate host specifications. |
-tag <TAG> |
Specify the TAG to identify the license server. The TAG may contain
only alphanumeric characters and underscores (_). The use of upper case
characters is recommended for style purposes. |
-tz, -timezone |
Set to timezone which was used to generate the debug log. Ex: PST8PDT.
If debug log was generated in the same timezone as the Monitor server, leave
blank. |
-checkouts |
Extract checkout information from debug log. This can be used to
monitor checkouts that are shorter in duration than the sampling
rate. |
-host |
If monitoring debug logs from triads, use this option to denote the
server from which the data originates. |
-minPeriod <TIMESPEC> |
Minimum sampling period. |
-maxPeriod <TIMESPEC> |
Maximum sampling period. |
-autokill <TIMESPEC> |
Kill parsing job after specified time. |
