Command Line Setup
An advanced user may want to use the command line to setup LicManager. All necessary files are in the directory licmon.swd/licmgr and the utility to use is called ftlm_licmgr_init.
The utility ftlm_licmgr_init can be used to initialize the license management subsystem from the command line. Here is its usage:
ftlm_licmgr_init: Usage Message
  DESCRIPTION:
      Initialize the licmgr/current directory for LicenseMonitor.
      This is the directory where copies of the active licenses
      are stored.
      This script is normally called automatically by ftlm_licmgr.cgi.
  OPTIONS:
      -tag TAG     -- Only update for specified tag
      -cvs         -- Initialize the CVS vault
      -templates   -- Initialize the templates for each known tag
      -reread      -- Reread configuration files.
      -v           -- Increase verbosity
      -h           -- This help message
  EXAMPLES:
      % ftlm_licmgr_init -cvs
      % ftlm_licmgr_init -templates
      % ftlm_licmgr_init -templates -tag MGC
The common sequence to initialize the system is the following:
  • Initialize CVS.
    % ftlm_licmgr_init -initcvs
    This step may fail if CVS is not available on your Monitor server machine.
  • Create the initial templates.
  • Edit the templates to activate them. This is mostly done manually, since a lot of the information required to start and stop the daemons is not automatically retrievable from lmstat.
    % ftlm_licmgr_init -f
  • Create the jobs in the system. This step needs to be repeated each time the configuration files are changed.
