-cmd <PATH> |
Choose a specific sampling command. The default is
LUMblt
-col |
Specify that the LUM server being monitored is serving concurrent
offline licenses. |
-host <HOST> |
-port <PORT> |
Set artificial server port to show in reports. Default: 0. |
-tag <TAG> |
Specify the TAG to identify the license server. The TAG may contain
only alphanumeric characters and underscores (_). The use of upper case
characters is recommended for style purposes. |
-trackdenials |
If provided, denial information from denials in addition to
usage. |
-tracktestlics |
Track common LUM test licenses, such as iFOR Test Product and HAL Test
Product. |
-tz, -timezone |
Set to timezone which was used to generate the debug log. Ex: PST8PDT.
If debug log was generated in the same timezone as the Monitor server, leave
blank. |
-minStatPeriod <TIMESPEC> |
Minimum sampling period for usage. |
-maxStatPeriod <TIMESPEC> |
Maximum sampling period for usage. |
-maxInfoPeriod <TIMESPEC> |
Maximum sampling period for expiration dates. |
-minDenialPeriod <TIMESPEC> |
Minimum sampling period for denials. |
-maxDenialPeriod <TIMESPEC> |
Maximum sampling period for denials. |
-infoAutokill <TIMESPEC> |
Kill info parsing job after specified time. |
-statAutokill <TIMESPEC> |
Kill stat parsing job after specified time. |
-denialAutokill <TIMESPEC> |
Kill denial parsing job after specified time. |
