Dassault DSLS
Usage
add_DSLS [OPTIONS]
Options
cmd <PATH> Choose a specific sampling command. The default is 'DSLicSrv'.
-host <HOST> Specify license server host.
-port <PORT> Set artificial server port to show in reports. Default: 0.
-tag <TAG> Specify the TAG to identify the license server. The TAG may contain only alphanumeric characters and underscores (_). The use of upper case characters is recommended for style purposes.
-minPeriod <TIMESPEC> Minimum sampling period.
-maxPeriod <TIMESPEC> Maximum sampling period.
-autokill <TIMESPEC> Kill parsing job after specified time.
-usekeystore Use DSLS key store file ($SWD/vovlmd/TAGNAME.ks) for authentication.
-robust Warn and ignore unparsable license usage output lines.
