License Keys
Altair Accelerator license keys are more reliable than RLM because they are simply a file that the Altair Accelerator product server reads directly instead of communicating with an external daemon to get licenses. If you have multiple Altair instances, RLM may be more manageable, because there is only one license file.
If license keys are activated, the products do not interact with RLM. This type of licensing is supported for Monitor and Accelerator instances. FlowTracer does not use this type of licensing.
License Keys Description
License key files can be installed either in the local directory of the installation tree or in the product-specific server working directory (SWD). License keys installed in the local directory must be in the format of license.productcode.key, where productcode is one of "lm" or "nc".
- The file named by the environment variable VOV_LICENSE_KEY, if set. This should be defined in the project's setup.tcl file.
- SWD/license.<productcode>.key
- SWD/license.key
- $VOVDIR/local/license.<productcode>.key
The license key encodes the host IDs of the hosts where the application is allowed to execute and the maximum allowed number of tokens provided by the license.
The following is an example of one such license key, to enable an Accelerator project (product: nc) on port 6271 on a machine called mac05 for up to 100 slots (license for: 100 slots).
# -- VOV License Key Information --
# License S/N: 20161110a
# VovVersion: 2020.1
# Product: nc
# Licensed to: rtda
# For host id: MAC:00:25:00:9f:76:68
# For host: mac05
# For port: 6271
# License for: 100 slots
# StartDate: Tue Nov 10 10:29:25 2019
# Expiration: Thu Dec 31 21:00:00 2020
EFIFFF`gjdCEceFDdd`ekgMDEDMEBGheee`ejcGEiadeifogJA
iel`neC@`eca@EHAMDFAgeD@LENFedfdCEceJE`angFE`dn`AA
L@AAADNGkfA@IADEBAkaB@o`KEceADEFJGlfnbJEd`bdFBeeod
CDeehgidbaOEjgMENE`ejcOEhdeeieedadceMEGEcc@@AECEle
bdHDCEfbDEEBEDICIEIFAFEAG@oeLACDndLEDENAg`KFhgfdAA
BDddodCEbeJBddne@DFFaejeODjdD@AEAALDAAKGk`BDofCGl`
dek`@@OFidd`aeedadheheoeACGEee`eieedadeeceLEAEIGNG
`e
Multiple license keys can be concatenated into the same file and the combined value of all the license keys will be used by the application. The serial numbers of such licenses must be distinct. You must leave the comment lines that precede the encrypted section.
- If the license.key file is present, even if it is empty or invalid
- If the variable RLM_LICENSE is not defined
If the software is using the license key, vovserver manages the licenses for any vovtasker that connects it. The vovtaskers do not read the license key file.
License Keys for Products
- Product
- License Key
- Monitor
- The concurrent number of distinct users having one or more license checkouts is counted. There is no limit to the number of vovtaskers and agents that connect to Monitor.
- Accelerator
- With Accelerator, for each vovtasker, the total number of "slots" or of "cpus", whichever is smaller is licensed.
- FlowTracer
- Use the Reprise License Manager (RLM). FlowTracer requires floating licenses.
Checking the License Key
An easy way to verify a license key file is with the utility vovreadlicutil.
vovreadlicutil
usage: vovreadlicutil [-f filename] [-P port] [-p product] [-V version]
[-I hostid] [-tv]
-f: Specify a license file.
-P: Specify port number.
-p: Product name to test (nc,lm,ft,lam,wa,...)
-V: Release date of version to test, in YYYY.MM format
-I: HostId to test
-t: Generate Tcl array with license info
-v: Print version.
> source /<install_path>/<version>/<platform>/common/etc/vovrc.csh
% vovreadlicutil -p nc -f vnc.swd/license.key
License S/N: 20160909T153538
VovVersion: 2020.1
Product: nc
Licensed to: Altair
For host: mac05
For port: 6271
License for: 40 slots
StartDate: Thu Sep 9 06:35:38 2019
Expiration: Fri Dec 31 12:00:00 2021
vovreadlicutil Nov 14 14:11:27 Valid for product nc
vovreadlicutil Nov 14 14:11:27 Valid for this host MAC:00:25:00:9f:76:68
vovreadlicutil Nov 14 14:11:27 Valid for port 6271
vovreadlicutil Nov 14 14:11:27 Valid for version 2019.01
vovreadlicutil Nov 14 14:11:27 Valid expiration (still 112d21h to go)
vovreadlicutil Nov 14 14:11:27 The combined license is:
VovVersion: 2020.1
Product: nc
Licensed to: Altair
For host: mac05
For port: 6271
