Installation Media and Supported Platforms
The Altair License Management System software is available for download by registered customers through Altair Connect.
Download the images for the platforms on which you expect to run the license manager and usage report system. If you plan to run the license manager and the usage report system on multiple servers, download the proper packages for all servers.
Compatibility
You cannot run two versions of the same type of Altair license managers on the same server. However, you may run older FLEXlm based versions (10.0 and prior) alongside the 11.0+ system. Be sure to specify different ports for each server.
