You will need a license file supplied by Altair Engineering, Inc. to complete the
licensing process. If you do not have a license, contact your account manager at
Altair Engineering, Inc. or your local Altair support office for assistance. With
your request, provide the Hostid value of your license server.
To obtain the host ID for the machine, run the following command:
<install_location>/bin/almutil -hostid
This provides all the Altair supported valid Hostids for this machine.
If you are using one of the Ethernet based Hostids, choose one that is on a
permanent interface. Some interfaces are for VPNs or other software based
adapters that may not always be present.
When you receive your license file, place it in the
<install_location> directory. By default it should
be in a file named altair_lic.dat. You can check the name
by looking in the altair-serv.cfg file and finding the
value for LICENSE_FILE.
- Optional:
Change the setting in the altair-serv.cfg file to point to your new license
file, if necessary.
